Engine Check light/ VSC lights on NEED IDEAS!
Old 09-19-08, 06:16 AM
Debonair
iModerate
Debonair's Avatar
Originally Posted by j.tom
Update:
The check engine light and all the other vsc light's just went away by itself, it came back on a few times, but drove normal then started acting up again with having to floor the gas pedal to get the car moving. Right now the codes are all gone ..drives normal and smooth again.
Wierd.
Just because the lights are off does not mean the codes are gone. You can still have the system checked to find out what went wrong. Its a good idea so you can prepare yourself for when it happens again.
Old 09-19-08, 09:09 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Agreed...
Also, have you done anything to the car lately? Changed the spark plugs, added an air intake etc etc?
Old 09-19-08, 01:38 PM
j.tom
j.tom's Avatar
Originally Posted by Rock-a-Lex
Agreed...
No,Did nothing to the car!
Old 09-19-08, 01:44 PM
White98ARISTO
Goldmember
White98ARISTO's Avatar
This happen to me before. I had a bad MAF sensor. I installed a new one and the problem never came back.
Old 09-21-08, 05:21 PM
j.tom
j.tom's Avatar
The code is P0121
Old 09-22-08, 11:16 AM
Debonair
iModerate
Debonair's Avatar
The code is P0121
P0121: Throttle (TP)/Pedal Position Sensor "A" Circuit Range/Performance Fault.
Either your TP Sensor is bad or your ECM is bad. Really no chance of the later so just replace the sensor.
FiveSeven
08-28-17 11:30 PM
foreste1
02-19-17 01:14 PM
rhwimmers
10-05-09 08:36 AM
D.Steezy
07-03-09 12:30 AM
06i
01-13-08 07:23 PM
Quick Reply: Engine Check light/ VSC lights on NEED IDEAS!
