0-60 Times
Old 09-22-08, 10:43 AM
jcat_350
jcat_350's Avatar
Originally Posted by ZinikGS
My mom's '91 Infiniti Q45 has the same 2nd gear start, only starts in 1st if you floor it. It can make the car seem sluggish off the line.
I have a GS400 and think I may have heard that this car also has the 2nd gear start, does anyone know if this is true?
yes its true.
btw guys haha look at the edit in my post, i retracted my statement because i found the site again and realized i had looked at the wrong car
Old 09-22-08, 10:56 AM
Vadim540i
Vadim540i's Avatar
Not mine, my gs4 always starts from first even in normal mode. If I'm braking before stoplight, and suddenly stoplight turns green, and car is still rolling 8mph, it starts from first too. So I have to be gently with pedal, r it will jump forward lol
Old 09-22-08, 10:58 AM
Kyle Harty
Kyle Harty's Avatar
I thought that it starts in 2nd gear when you turn on the snow mode to cut wheel spin, and otherwise would start normally in 1st. Maybe I read that wrong. My 400 jumps pretty easily off the line, it took me a little bit to get a feel for starting off smoothly. I drove someone elses car the other day and noticed how much more effort it took to accelerate. The GS it seems like I barely hit the gas and I'm going 30.
Old 09-22-08, 11:05 AM
DarKnight
DarKnight's Avatar
The same thing happens to me. Sometimes I just press it lightly and the car lurks forward. I think it's because of the whole thing where the ECU memorizes your driving style. Like there are times when I'm accelerating normal and the car is overrevving but not accelerating as it should because it's expecting me to be mashing the gas.
Old 09-22-08, 11:40 AM
UpstateLex
UpstateLex's Avatar
is there anyway to reset the ECU ?? and if so is it ok to do?
Old 09-22-08, 11:45 AM
TruPlaya26
TruPlaya26's Avatar
Just disconnect the negative battery terminal for about 10 - 15 minutes and you should be fine ... And yea it's alright to do, you can do it as many times as you'd like, but remember that you will lose your seat memory positions and your set radio stations. Just redo them, and you'll also need to set the time lol
Old 09-22-08, 11:46 AM
jcat_350
jcat_350's Avatar
disconnect the negative battery terminal for ~15 min or so. it is fine to do it, but you will lose your radio presets, maybe seat memory?
Old 09-22-08, 11:52 AM
ZinikGS
ZinikGS's Avatar
That sounds accurate. My car doesn't feel sluggish off the line, I just thought I remembered hearing that about the 2nd gear start. Maybe I thought that because in manual mode it doesn't let you shift below 2?
Old 09-22-08, 12:19 PM
Vadim540i
Vadim540i's Avatar
You're right. Only in snow mode it starts from second.
Old 09-22-08, 02:52 PM
UpstateLex
UpstateLex's Avatar
good looks truplaya and j cat
Old 09-22-08, 03:15 PM
DarKnight
DarKnight's Avatar
You can pull the ECU fuse for about 30 minutes so that you don't lose your presets.
Deception
03-24-08 09:26 AM
Zoraone
10-17-07 11:07 AM
coolcow
ES - 5th Gen (2007-2012)
05-03-07 07:52 AM
LexusIS-TL
03-01-07 02:12 AM
BadBtsz4u
01-03-02 02:52 AM
Quick Reply: 0-60 Times
