Piggyback
Old 09-27-08, 06:08 PM
fordsvtmfl
fordsvtmfl's Avatar
Default Piggyback
Is there a piggy back that will control air/fuel and engine control? (ie rpm limits etc..) and if there are a few, which one would you recommend (and i am looking for the best bang for my buck...I just bought a full set of snap-on tools for my automotive classes...sooooo im not exactly looking to spend a ton...)
Old 09-27-08, 06:25 PM
jcat_350
jcat_350's Avatar
apexi AFC-neo, will run you about 3-400, but will offer excellent adjustability. Most guys run this in conjunction with a K&N intake to replicate the effect of the SRT, most of the time with great results.
Just get it installed and dyno tuned by a good shop or install it yourself and get it dyno tuned correctly and you should be able to see some decent gains.
Old 09-27-08, 06:27 PM
fordsvtmfl
fordsvtmfl's Avatar
i have looked at that...but will that allow me to change my rev limit/shift points?
Old 09-27-08, 06:31 PM
jcat_350
jcat_350's Avatar
that i do not believe it does...it is strictly an a/f tuner. I'm not just sure anyone makes a unit to alter shift points on our cars outside of doing a full factory ecu reflash
Old 09-27-08, 06:46 PM
fordsvtmfl
fordsvtmfl's Avatar
what is the hp increase supposed to be with the k&n and the neo? (i have a CAI with a K&N..so what kind of increase would i see from what i already have?)
Old 09-27-08, 06:47 PM
jcat_350
jcat_350's Avatar
i think there's a thread about this that you may have posted in, about SRT+ECU vs. the K&N and Neo...check that out.
Old 09-28-08, 01:08 AM
GS FONZy
GS FONZy's Avatar
If you are looking for a A/F controller, then go with Camcon. You will get the bonus of a VVT controller as well, that would be the best bang for your buck.
As for shifting, raising the rev, only a stand alone ecu can do that and not all of them can, so that means some serious $ will have to be spent.
Old 09-28-08, 02:32 AM
JeffTsai
JeffTsai's Avatar
Only a standalone will allow you to raise the rev limit. The stock ecu will let you wind out the gears higher if you have a raised rev limiter. I currently have my limiter set at 7600rpm and the car shifts at around 7400rpm if I just leave it in D and gun it.
Old 09-28-08, 07:52 AM
fordsvtmfl
fordsvtmfl's Avatar
how do you raise the rev limiter?
Old 09-28-08, 08:22 AM
shvc1991
shvc1991's Avatar
Through a full ECU reflash.
Old 09-28-08, 10:11 AM
jriggs
jriggs's Avatar
stand alone and re flashing are the ways to raise the limiter, unless your going f/i i don't think there are many advantages to raising the limit.
have you used the Camcon units before? any links to vvt tuning with those units and effects (pros/cons) of changing vvt points
Old 09-28-08, 10:35 AM
fordsvtmfl
fordsvtmfl's Avatar
the camcon unit looks sweet, but i cant find one for sale anywhere! ebay only have 1 and its for honda's will the is300 camcon plug and play into a 98 gs3?
Old 09-28-08, 12:19 PM
jriggs
jriggs's Avatar
fordsvtmfl - power enterprises (maker camcon) website lists distributors here's a link to one
http://www.erzperformance.com/Produc...Code=PE-CC-101
and heres the page with the distributor list
http://www.powerenterpriseusa.net/di...ors/index.html
Old 09-28-08, 12:26 PM
jriggs
jriggs's Avatar
side note - doesn't the apexi neo also control vvti or does it only control vtec?
Old 09-28-08, 05:48 PM
GS FONZy
GS FONZy's Avatar
Vtec only.
Quick Reply: Piggyback
