Remote door lock lights NOT flashing???
Former Sponsor
This just happened today
I went to unlock my car and the lights didn't flash to let me know that the car was unlocked? I looked at all four locks from inside the car and they lock and unlock fine, but the lights don't flash what could this be?
I might say check your hazard lights. Go inside the cabin and push the hazard light button. Check and see if the lights are flashing outside. If they are not it is probably the plug not being plugged into the back of the hazard button... or it is the fuse for the hazards. The lock/unlock functionality is all based upon the hazard system.
hope that helps...
-Joe
hope that helps...
-Joe
Former Sponsor
hope that helps...
-Joe
hope that helps...
-Joe
That's the problem, I have the clock,radio,HVAC out because I'm changing the color. The hazard wasn't plugged in, I just put it back in and the lights now flash. I guess that the hazard button closes the circuit, good call joe!
I have LED turn signals installed, as you know LED's draw less power so the stock flasher relay would function only as if one of my signals were burned out; flashing rapidly. Had to change to a relay that's rated for the low power LED's use. The drawback however, is that my signals don't flash when I arm/disarm my alarm.
or I could have changed some sort of setting with out knowing
....lol
You need to use something called a resistor... It makes the computer think that you are drawing 12V which is what it is looking for... a normal LED uses I think 5V therefore, it will flash rapidly. I have LED turn signals in the rear and I had to resist those bulbs because it would do the very fast flashing thing. Now that I have added the resistor, the signal flashes normal, and the lock/unlock works just fine!
-Joe
-Joe
-Joe
-Joe
