actually the 2-piece 22's are not that heavy as people seem to think ! and its not that much more of stress on the tranny from the larger diamater tire! the difference from the 20 to the 22's is exactly 1" my 20's was 26.6" tall and my 22's are 27.6" tall ! and my 22" is lighter in weight than my 1-piece 20's !
Your right about that, 22's can be lighter that 20's if there made of lighter material, speedometer might be off though, watch out of those traps!
yeah actually i think its off about 5mph when im doing 65mph im actually doing about 70mph! if i dont sell the car, im going back to staggered 2/3-piece 20's and laying it out !
Doesn't look that bad but you need some aero/bodykit, something. The oem body lines are way too short for this big of a wheel. a clean bodykit and it might look decent.. congrats..
I'm with him on this one. Although; It does not look that bad do to the fact that you lowered the car a bit, you still need to figure out a way to get the body lines closer to the ground. There is a huge space from the ground to the oem side skirt that you must bring closer to give it an even better look.
actually it did rub when i first put them on ! i just had to shaved the fenders about 3/8" of an inch all the way around ! especially in the rear with the 285 tire. and the rims weigh aprox. 15.25kg/33.55lbs each. which isnt to bad for a 22" rim ! yeah the only thing that really bothers me about running 22's is the 4x4 stance of the car ! i think even if i drop it in the rear to even out with the front its still going to be kinda high even with a bodykit also ! so im shopping for new 2-3 piece 20's already ! i got my eye some MOZ "V-10 or BRANDENBURG" front 20x8.5 40mm offest and rear 20x11 50mm offset
