I had these amps for a while when I use to compete in spl. with the DD I hit 153.2 db, Maybe cause its Hawaii but its hella loud. The amp is putting out 64 volts ac which is about 4096 watts, so I know these amps work. So 2000 watts a sub is about right. This is an old spl set up. If I wanted clear I would have used the 6000 series DD's. I roll so you hear me before you see me..
Or I could just drop 2-4000 watt amps.
ok is this 6500w better lol
sounds on top...air on the bottom..
and the valves sit behind the back seat..
I like this one
Anyone have dual kickers L7 w/ a complete face like the one in the above picture and still have access to their spare? I would love to have something like that for my set-up.
I like this one
Here is my contribution. So, I did got the trunk set-up I was inquiring about
Dual L7 12" subs, 4 amps, secondary yellow top battery and I still had access to my trunk.
some ppl on chassy, some ppl stright from battery, there is just so many ways to connect things by your set up. like if you have additional battery or relocated battery in trunk, then no long wire needed.
foolish if people ground at the battery. Ground battery is NEVER to exceed 3ft and should be as short as possible and on a panel which is directly connected to the unibody.
