damn, I have to balance the tire every two weeks!
Have you ever mounted a tire before?
I think something is wrong with your conception of how tires attach to rims.
Google finds this article that explains with pictures: http://marktg.toyotires.com/file/rimslip.pdf
wow..it is very good article to share with
So if i didn't unmount the tire. will it dry winthin two monthes?
If it's still slipping even after the lube is dried, then either your particular choice of tire and wheel just don't get along or there's a lot of crap on the wheel that wasn't cleaned off.
In either of these cases, you are best off just having your tire professional make the appropriate changes for you, since they are doing the work anyway. No need to second guess them unless they are letting you down. Maybe they will have you choose a different tire with a different bead. If they are well trained tire place with competent ppl, they will be able to see what happened and help you way better then a bunch of people on the internet.
Get it checked for balance without unmounting. If the balance is off, then your tire people have work to do. They can check to see if it was because of slip or because of missing weights. They can mark your tires and find out.
Thanks!
