Replacing steering wheel with something else?
connectors are just a less permanent way to connect the wires. i'm not sure what cluge means, but as long as the battery is disconnected while you're doing it you won't have to worry about it popping out on you.
that looks like theres only a ground coming from the connector. I would think you would have to do a little wiring to get it to work but it should be doable.
https://www.clublexus.com/forums/sho...d.php?t=381720
I think if you look closer at the picture, especially in the center of the airbag charge, you'll see 2 orange colored wires that appear to be covered under the opaque white plastic assembly. These appear to be attached to the white connector in the foreground of the picture that is out of focus.
The TRD steering wheel looks fantastic.. The first time I laid my eyes on theTRD steering wheel was on Martin Kraft's Gs400 on overboost.com back in 2000. I am suprised the airbag wiring harness is not compatible with the Gs400
I don't know how Steve found out that the airbag won't deploy on impact. I guess that someone with that steering wheel got into an accident and it did not deploy? Otherwise it would say "harness not plug-and-play" instead of "won't deploy on impact".
That's where I first saw it too, on Martin Kraft's GS400. It is simply amazing.
