How to switch map light bulbs?
I was wanting to know if anyone had any idea how (or if it was possible) to change the map light bulbs in our cars? I am referring to the lights in front of the sun roof. They are a very dull yellow and I wanted to change them to something whiter.
Is this possible? What bulb sizes and types should I use?
I tried the search function but nothing came up so if someone else has more information or can point me to a thread I would greatly appreciate it.
Thanks
Thanks
That plastic cover pops right off... but the two map bulbs were an odd side... I changed the center bulb and had to leave the map bulbs. You can probably just wire in an LED board if you've got the time.
you can find led bulb replacement so theres no splicing or wiring needed. That's what I did. do a search with my name and led lights, I think I posted a link somewhere that tells you the bulb size of every bulb on our car.
I'm actually in the midst of my LED/HID review thread.
I bought all of my parts from V-Leds.com
http://www.v-leds.com/Shop/Control/fp/SFV/32481
It can be a very difficult choice because the site has tons of options. But I talked to a rep through email and found a VERY good solution. I know they have bigger LED boards for the dome light. However, I wanted it to sit recessed from the cover so it didn't show LED "hot spots". The map lights are positioned so they fire directly into the focal point of the lens. The finished product is an extremely bright display without hot spots or glare issues. All of the light fires down instead of into my eyes while driving.
The representative helped out a lot with the suggestion to open up the housings first and check out what works best, because there is a lot of engineering from the factory as to how it will work best, so cramming as much as you can in there isn't always the best way...
Heres a quick photo (makes my headliner look gross
), I'm going to do a full writeup in a week or two, the car just came out of the body shop. If you'd like part numbers I can dig up my invoice so you can order easier.
![](http://i531.photobucket.com/albums/dd352/JacksonVaughnAlbum/GS300/led.jpg)
Please ask me any questions you have, I want to make this writeup very thorough, so let me know what I should include.
-Jackson
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
-Jackson
Blurry.. but you can see how I set mine up. BTW, my mistake, they are 4LEDs.
![](http://i36.tinypic.com/33djjbq.jpg)
![](http://i37.tinypic.com/161kpw.jpg)
![](http://i38.tinypic.com/2gwuhoz.jpg)
Ridiculous as in.. not bright at all! The reason why that is is because the LED points to the side rather than point down. An angled LED bulb or a LED board would probably solve that problem.. but for now I'll stick with what I have since I don't use that light that often anyway.
