DIY Valve Cover Gasket Replacement on a 1999 GS300
Does anyone have info on replacing the valve cover gasket on a 2nd Gen GS300? Mine is leaking and needs replacing. I would like to have a PDF file from the repair manual.
hey curtis, your can follow this spark plug instruction to take out the throttle body. to take out the spark plugs.
https://www.clublexus.com/forums/sho...d.php?t=116654
in the meantime i will post up pictures of exploded view. when i removed the throittle body i didnt have to disconnect any of the hoses but one that is closest to the passenger side which was not pressurized.
speedkar9
11-01-16 02:04 PM
