are all strut tower braces the same?
Ideally, you want one that doesn't have a pivot joint like the bars offered at tcsportsline. Some bars are more rigid than others so quality is pretty much in the equation.
However, no one makes a bar that's remotely effective because of the design. I guess marketing got the best of most people
Master Thread Closer!!
Every manufacturer gives us reasons to think their design is the best. There is always going to be debates about STBs with a pivot point design (ie: RMM) vs. the one solid piece design (ie: TRD and Carson/Carbing).
You want to make sure you get the one that fits....most ppl don't want to remove their engine cover....and prefer ones that fit over it.
The similar designed strut bar I had on my Legend (The MLS one) also made a noticeable difference in feel. Again, not saying these things dramatically help performance, but it definitely helps solidify the front end and steering feel and feedback has been improved in my experience. That alone is worth it for me especially on a Lexus which could use help in that area. For some, they don't want this extra feel and feedback in the steering wheel as it is not Lexus like and you feel the more road, but I actually like that so it works well for me.
Yes chris. There will be some difference, but will it be as effective as it can be? Of course not. The 1-piece bars are quite bit better than the pivot jointed bars just because there is less flexing going on. However that isn't to say that's the best design when it comes to minimizing flex. A triangular bar that connects to the firewall is the best design when it comes to distributing stress point. It's just a simple case of statics for rigid bodies.
So the solid pieces are pretty good, but far from being the most effective.
I think more importantly, it's how you install it.
Make sure you jack your car up then install the brace so it'll have equal load on each side. Trivial, but trust me, I've felt differences in some cases.
Never thought about that actually, do people actually install it this way?
Don't think I've seen a 1 piece on on ebay before lol. I think another big factor is how thick the bar is. The cheaper ones are obviously going to have less material. The expensive ones are going to have a thicker bar section. For example if you've seen the Tein strut bar in person. That thing is BEEFY!
if the trd fit gs430 without having to ditch engine cover I'd have one of those.
I didn't like the look of the design for the carson gs430 one. It looked flexy because of how high the bar mounts are. but I've never tried it. if CK6Speed says he felt it, I have no reason not to believe him.
GS430 clearance:
GS430 clearance:
Im using tein bars on my 430 because I also have tein coilovers and for the fact that they look and feel very massive and rigid. I think that by installing them they helped in rigidity and noise level. Coilovers tend to be a bit on the noisier side than stock suspension so after I put the bars on the suspension noise went down a little. This could be debated on and on until someone does some actual testing which im sure no one wants to spend the money on as to figure out which bars help out the most. Imo its a matter of choice as to which bars you use. I just stay away from ebay brand.
