My HID Bulbs Dont work Sometimes
Hi,t i have my GS400 1999,tha happen is the low beam hid stop working i will take the hid bulb off the head light will cheked looks good i put the hid light back in the head light and then will start working ,the question is i have to change the hid bulb or the ballast is bad i apreciate you guys help,this situation make me sick, thanks . JR
Do you have a aftermarket HID? Check connections, tape any connections with electric tape if suspect loose. I taped my old car that had a bad connections, and no problem after all.
Hi,t i have my GS400 1999,tha happen is the low beam hid stop working i will take the hid bulb off the head light will cheked looks good i put the hid light back in the head light and then will start working ,the question is i have to change the hid bulb or the ballast is bad i apreciate you guys help,this situation make me sick, thanks . JR ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
chuggie
Lighting
04-13-06 10:29 PM
bulb, doesnt, dont, headlight, headlights, hid, intermittent, intermittently, is250, isometimes, lexus, ligts, stops, work, working, works
