For the Gs guys with air bags....
This is probably a stupid question but can I ride low with air bags? The reason I ask is because when I drive really low on bags, my car wiggles like crazy when I hit a bump.
also will I have to change the rubber bags at some point?
will my bags pop? when there is too much weight in the car? I usually buy a lot of inventory for my store so sometime my car can get really heavy
Thanks guys
Thanks guys
I don't want to high jack your thread, but I also have questions about bags that I cant seem to find answers to when I search...how reliable are bags for daily cars and how long will they typically last? Also not only worried about the bags (although I hear they are reliable) what about compressor motors burning out, or being stuck without the bags being able to inflate? I would like to bag my car just because I don't want to worry about where I am driving and if my car is going to be too low to get in and out of places...TIA
although i don't have bags, nor do i know much about them.. i don't think it's smart to ride low on bags, i can just assume the tension it puts on them.. drive high and park low
I can drive pretty low but just have problems with the tires hitting the top of the wheel well right now.
I pretty much have the same setup as you. As far as fender mods and wheel specs go.
Are you using valves or a manifold setup?
Thanks guys
Thanks guys
I've had my UAS for about 4 years and there's no sign of wear. I also don't have wiggling problems at any height. I could ride tuck, but my wheel offset would damage my front fenders. So I keep it at a decent height for daily driving. I did use the universal chapman struts from Easy Street, but didn't like the softness of the ride (specially at low pressure). There was also significant bodyroll on the chapman air sturts that I wasn't use to coming from coilovers.
As far as bags popping, this will only happen if you apply too much pressure or you exceed the maximum weight allowed for a certain bag or a combination of both. Your own car can create pressure and/or additional weight just by going up and down, so you have to account for that factor also.
I'm at work so I can't post pics but I assume you have the first set of valves.
Do you have the valves like these
http://www.fbirides.com/product.asp?idno=8289
or like these
http://www.fbirides.com/product.asp?idno=8288
It was just a thought if you have valves like the first set you should have 8. If you have 4 then your sharing air which makes your car wobble.
or like these
All bags are created differently and are operated in different ways. It's hard to predict how long is the life time of the bag, specially if there's so many different variables involved.
I do drive my car daily and log about 12k-18k per year.
or like these
or like these
