My Car Isn't Starting - Not The battery - could be the key
Old 02-22-02, 02:03 PM
LexusRules
LexusRules's Avatar
Exclamation My Car Isn't Starting - Not The battery - could be the key
ok when i try and start it its like DU DU DU *starts* for like 1 millasecond its started.. then BOOM dead and *still holding key on start* the starter keeps going...... as long as i want and the engine never tries to start again. unless i wait 5 min with the key out and try again. the engine starts for a split second then dies.
im pretty sure (with richy's help) that its the imobilizer not letting the engine start... i thinks im hotwireing the car because my key's chip is dead i THINK. just wanna know if it could be anything else.
i have no spare key to test until tuesday. thanks
Old 02-22-02, 02:18 PM
Richie
Richie's Avatar
Sasha, if you keep starting you keep hearing the starter motor turning.
It sounds like there is not getting any fuell in the cilinder.
So there is an obstruction there.
Old 02-22-02, 03:20 PM
LexusRules
LexusRules's Avatar
in a sence ill be happy if its that... because i was telling the lexus techs and they told me it was fine.
Old 02-23-02, 06:53 AM
biggie27
biggie27's Avatar
hey sasha it could be that your intake has a problem check your sensors it could be that the sensor is loose
Old 02-23-02, 07:31 AM
LexusRules
LexusRules's Avatar
thanks man... i dont think thats it tho... i've had this intake a long time nothing has changed.. i will check the sensor though.
Old 02-23-02, 09:06 AM
ShowGSLuVv
ShowGSLuVv's Avatar
I had a problem almost like that with my Grand prix, If you want to try this, Buy some starter fluid, and spray it inside ur intake, then try to start the car, and if it starts and stays on for a couple seconds, then turns off..... then it could be ur Gas pump thats located in the gas tank, not the injector.... atleast that's what was wrong with my car when it would do that, if you ever find out what it is let us know, just for future reference
ShOwGS
Old 02-23-02, 10:02 AM
Richie
Richie's Avatar
Sasha, what is the latest news???
Old 02-23-02, 10:31 AM
LexusRules
LexusRules's Avatar
still NOTHING man.. so time didnt help. im worried about the car a lot now.... my mom will be back tuesday but i dunno if i can wait that long
Old 02-23-02, 12:27 PM
Richie
Richie's Avatar
So what are you going to do now??
Old 02-23-02, 01:25 PM
LexusRules
LexusRules's Avatar
wait for my mom to get back from florida...
Old 02-23-02, 09:38 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Does the remote lock/unlock work with red led lighting up on the key? There is only one battery in the key.
Do you have any other "active" [some thing that sends electronic signals] in the key ring confusing the receiver?
Salim
Old 02-24-02, 05:11 AM
LexusRules
LexusRules's Avatar
i checked the MAF its in there good n tight so i cant see how that is the problem.
I took my keychain off and started the car still wont go...
my key is the spare with no batteries but i have started the car before with this key, its the vallet key.
Old 02-24-02, 05:43 AM
Richie
Richie's Avatar
Good luck when your mom gets back then!!
Old 02-24-02, 06:36 AM
altaf
altaf's Avatar
Have you tried calling Lexus roadside assistance?
stpete
01-30-21 09:31 AM
2k4CamkilA
01-21-16 06:49 PM
RUDENESS
03-18-07 08:31 PM
xGSxDUBZx
12-04-06 01:55 PM
92lexus
Maintenance
12
02-13-03 07:14 AM
Quick Reply: My Car Isn't Starting - Not The battery - could be the key
