Greetings need some advice for the old girl
Progress
Well,
The coil pack are good, compression is good. The mechanic says they are going to investigate the wiring and ecu. Went in person, man I miss my baby.
Well the codes being pulled now are:
1. p1349- P1349 VVT System ( Manufacturer controlled ignition on misfire)
2. p1656- P1656 OCV Circuit (manufacturer cotrolled computer output circuit)
With the info here: I asked if the injectors had been tested and he stated that they were moved to different cylinders and the codes are not following the injector.
Thanks y'all
I'll keep updating
Thanks y'all
I'll keep updating
About to lose it
Well the car has been out of commision for three weeks, and I feel that the mechanic is just replacing parts.
so far, changed
Timing belt, water pump, serpentine belt.
Idle control sensor.
Bilstiens struts.
One day the mechanic says its the ECU, today says the throttle control sensor.
please help....
Should I just take it to someone else?
so far, changed
Bilstiens struts.
please help....
19x11.5 -51
I am having problems even starting , starts and dies over and over ...... thanks for keeping us updated . I am trouble shooting too but cant use a obd2 reader when car isnt even running . ?
thanks for updates
How can you test a coilpack Thomas ? or even wires ? if I have a low spark in one cyc Should i check all of them or look at the next thing in line
thanks for updates
Got my baby back
Well, got her back and I'm going to list everything that was replaced.
Throttle body replaced
VAcuum Hose
Accelerator pedal sensor
I am not sure what actually fixed the problem, but the final piece was the throttle body. Also replaced shocks and timing belt and water pump, but these were preventative.
Hope this helps someone,
VAcuum Hose
VAcuum Hose
VAcuum Hose
handoverfi
03-22-10 02:04 PM
