Can I just put HID Kit in my Gs without Modification?
Old 11-18-08, 12:41 PM
BilluAwan
BilluAwan's Avatar
Default Can I just put HID Kit in my Gs without Modification?
HI guys i jsut ordered 2 pairs 9006 complte kit from XenonDepot for my 98 Gs 300.... its obviously non HID from factory and uses Hologen Bulbs....Can i install the kit without any modifications or do i need to buy new HID Housing ...MY lights are in near perfect condition! Someone just told me i had to replace both housing for headlights in order to install after market HID...Is it True ?
Old 11-18-08, 12:43 PM
Deception
Deception's Avatar
nope buddy no modifications. everything should be plug and play.
Old 11-18-08, 12:46 PM
Debonair
iModerate
Debonair's Avatar
Your HID kit will "work" in your non-HID housings.
For them to work well and properly light the road without creating some glare the general consensus is that you will need a HID housing or HID projector conversion.
Old 11-18-08, 01:01 PM
BilluAwan
BilluAwan's Avatar
Thank you guys..you are the best....I just came to these forums like a week or so ago and appriciate all the help from you ....Thanks god i dont "Have to" Change the housing ..i already spent so much money on the car getting audio setup lighting etc that i need to calm down lol....I just sold my Acura TL and upgraded to Lexus so i need to make this one also "One Of Kind" as I did to my TL! All help is really appriciated! CL is the best
Old 11-18-08, 01:02 PM
BilluAwan
BilluAwan's Avatar
Default Deception
Thank you man ! I see you seliing your Apexi ....how much and any info on it...u can pm me
Old 11-18-08, 04:25 PM
Mr.412
Mr.412's Avatar
what the HID's cost you?
Old 11-18-08, 04:34 PM
BilluAwan
BilluAwan's Avatar
$120 each ..they are Xenon Depot Volt kits 6000K .... i hope they are good ...anyone have experiance with them!
Old 11-18-08, 04:44 PM
Mr.412
Mr.412's Avatar
great when you get them in take pics and let us know what you think of them, and the 6000k is the white light right, not very blue like the 8000k?
Old 11-18-08, 05:30 PM
Deception
Deception's Avatar
apexi is 400. im still dealing locally tho. when i bought it it came in 2 huge boxes.
Old 11-18-08, 11:07 PM
MurdaInc
MurdaInc's Avatar
you might have to use a relay since the gs's have drl( day time running lights)
Old 11-18-08, 11:49 PM
L3XOTIC
L3XOTIC's Avatar
I have HID's in NON-HID housing and its perfectly fine. I get no complaints about glare or anything
Old 11-19-08, 06:01 AM
Debonair
iModerate
Debonair's Avatar
DRL's are hooked up to the High Beams. As long as you are only HID'ing your Low Beams you will be fine.
A good HID Kit should have a relay equipped harness anyways.
Old 11-19-08, 07:46 AM
jcat_350
jcat_350's Avatar
+1, as long as theyre aimed correctly you shouldn't have a problem. Though there are always those old timers who just get pissed off and flash you for no reason.
Old 11-19-08, 09:54 AM
PHML
Master Thread Closer!!
PHML's Avatar
Yes...it can be done....the only issue is the glare to on-coming drivers. So yes, you may get high-beamed for that.
Are you planning to put the other kit in your fogs? If so, beware. The heat in the fogs do not have room to dissipate quick enough....so it may possibly "blow up" in there.
Old 11-19-08, 10:14 AM
vietdeluxx
vietdeluxx's Avatar
I put HID in my old Scion TC with non-HID housing and it works well too!
Quick Reply: Can I just put HID Kit in my Gs without Modification?
