jp tail lights non led project
now i should go to the work shop and work there because i dont have the best tools in home after i worked there for 7 hours i finally finished cutting the cover and make it fit correctly now im driving home with one hand and the second was carrying the third brake lights becuase i paint them lucker for extra shine
first step: i open them by heating the cover by the hair dryer and with screw driver u can open them without heating it but plz be carefull becuase its can break up or scratch even with heating dont heat it more than limit just little bit if u kept heating it the plastic cover will burn
second step: opening the oem tails ( i cant open them becuase the factory dont use silecone as much the glue so it was hard enough and i broke the both plactic covers i was tearing becuase my tails was one month old)
third step: the led cover will not fit directly becuase both of them have deffrent size for the plactic cover so i shaved it from inside
last step:fixing and fitting by black silecone be carefull and close every big and tiny hole with silcone u dont want to have water in the lights after washing the car i add silcone 3 times to be sure theres no holes and it fits correcly
i hope thats i helped every one this is my first time opening my tails so u dont need to be profesor just be carefull.
