just DIYed my radiator, should i put coolant in the white thing on top of the fans...
i just replaced my radiator with a koyo aluminium radiator since mine was busted from the accident.
Followed a DIY i found on here and saved myself $200 or so. Pretty easy and it only took me about an hour from start to end. And that was in the freaking cold....lol
I bought some coolant and after installing the new radiator, i filled it with the coolant till it was full. Turned on the heat to full blast and allowed the car and radiator to get warm/hot to normal temperature(needle sitting at halfway).
i turned off the car and opened the rad cover (carefully cos it was hot) to allow steam/air to gush out. then i topped it up with more coolant.
What i want to know is that was the correct process to "bleed" the radiator?
Also, there is a white "coolant" container attached to/on top of the radiator fans. Am i supposed to fill that with coolant also. It is empty as of now. Am i missing anything?
Also, was i supposed to mix the coolant with distilled water or was the coolant alone ok?
BTW, If anyone has any questions on the DIY, i can definitely assist.
Thanks
olddog
Thanks
olddog
Did you purchase the pre-mixed 50/50 bottle or did you purchase the concentrate only? If you purchased the concentrate only you need to mix the coolant. I believe the bottle you are talking about is the over flow. You should fill the over flow up to the marked line for cold or hot depending on if the fluid is hot or cold.
i will check if it was mixed already. i think it was.....
Yup, you get twice as much product buying the concentrate as GSteg priced up for pretty much the same cost of 50/50. I would use coolant instead of water in the reservoir. That's if you have enought coolant. Coolant has a greater freezing and boiling point. That's why it's used.
You must have the 50/50 mix.
Right on the directions of the concentrate is says to add 50% coolant, then add water. How else are you supposed to dilute the concentrate?
Oh while were on it, you shouldn't open the radiator cap while it's still hot. You can get severly burned. Safty first.
1. connect the rad yo the top and bottom hoses
2. fill rad until full. leave the cap open however
3. start your car and turn your thermostat to full heat.
4. let the car warm-up to where the thermostat opens.
5. add coolant as needed.
6. when coolant rises to all the way to the top of the rad, add the overflow tank to 50%
7. after driving around, if there is any coolant missing in the reservoir, add some more.
*note: make sure you do this on an upward slope so you can get all the air out of the coolant system.
Agreed , you need to bleed without the cap on . The slope will not make a difference as the fluid is being circulated and that has more force than gravity.
Someone mentioned about filling the the res with water.
Unfortunately we are in Canada and it is below freezing , so that would crack his tank.
Just keep an eye on it for the next few days and top off as needed.
ToyotaLexus
RX - 1st Gen (1999-2003)
12-13-08 11:39 PM
