19x9.5 +22 245/35/19 tires front wheel clearence
Old 11-23-08, 08:46 PM
istundra
istundra's Avatar
Default 19x9.5 +22 245/35/19 tires front wheel clearence
Hello,
I would like to know if 19x9.5 245/35/19 would clear in my 2GS.
I have rarely seen people with 19x9.5 for fronts, but if it fits without fender mods, then that will be great.
Old 11-23-08, 08:53 PM
MrExecutiv
MrExecutiv's Avatar
It'll all depend on what your offsets are. What is the offset the the 19x9.5?
Old 11-23-08, 08:56 PM
GS FONZy
GS FONZy's Avatar
not happening
Old 11-23-08, 09:03 PM
KNEXX
KNEXX's Avatar
The offset is the key... I have a 20x9 w/ a 225/35 series and it fits just fine no mods no rub. I cant imagine a 9.5 would cause an issue, but that depends on the offset. You could get away with a smaller tire than a 245... I'd try a 225, bc I still have room to stretch it more.
Old 11-23-08, 09:06 PM
speedaddic
speedaddic's Avatar
would rub on the inside... he's got a +22
Old 11-23-08, 09:10 PM
burma
burma's Avatar
his offset is in the title....+22 on a 9.5 rim.
I would go with a 235 or 225 tyre because it will definetly rub with the 245. it might not rub on the inside because while it is a wide wheel, the +22 offset pushes it out away from the strut etc.. you will have to do fender mods if your planning to turn lol
Old 11-23-08, 09:11 PM
KNEXX
KNEXX's Avatar
I totally missed that... I have a +19 and there is room, unless +19 is the limit... I'd try it
Old 11-23-08, 09:12 PM
istundra
istundra's Avatar
ok this is sad.
Old 11-23-08, 10:14 PM
dRo15
dRo15's Avatar
It'll fit with a 235 and you will need some fender mods. How low are you?
Old 11-23-08, 10:18 PM
teamavr
teamavr's Avatar
Im on a +20 with 19s on a 235 35 series and im slam
evrything is kewl you just have to roll a little but if you aint that low then your good
Old 11-23-08, 10:19 PM
istundra
istundra's Avatar
i am lowered on tein stech springs. maybe 1.7-1.8" drop?
i prefer not to do fender mods, so i think this thought will definitely be reconsidered.
Old 11-23-08, 10:22 PM
dRo15
dRo15's Avatar
I think you'll be fine. From the pics I've seen, a 1.7" drop isn't much of a drop.
Old 11-24-08, 02:08 AM
chrispy
chrispy's Avatar
Going with a 235 in front will help if it doesn't clear.
Old 11-24-08, 02:53 AM
Mr Jokster
Mr Jokster's Avatar
I havent the clue about offset.. but I've got 245/30/22's (9.5's) with a 45 offset with a 1/4" spacer. no rub? IDK... just my worthless 2 cents.
Old 11-24-08, 08:22 AM
Jedidiah
Jedidiah's Avatar
won't be able to be very low without shaving the fenders and running in excess of -3 degrees of camber.
hunodos
05-08-19 10:15 PM
twinturboz
IS F (2008-2014)
12-05-10 11:03 AM
bighitbike
06-11-07 10:23 PM
AJ
Wheels, Tires & Brakes Forum
01-16-07 01:53 PM
Tim
01-04-06 01:37 PM
Quick Reply: 19x9.5 +22 245/35/19 tires front wheel clearence
