Anyone else notice the cluster (dash) back lighting seems dim?
Old 12-13-08, 12:10 AM
  #46
skperformance
skperformance's Avatar
From using the product a few years ago it is very bright for its size.
Considering the back lighting is as dim as a candle at night , this would be a major improvement.
Old 12-13-08, 01:39 AM
  #47
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Its very strange your having this issue. Is your sensor reacting to the light well?
Could be be someone adjusted the settings for the lighting sensor via C-best settings before you purchased it (one that controls how early your sensor triggers the AUTO lights, which may have manipulated the way it operates). Just guessing here.
Old 12-15-08, 10:55 PM
  #48
skperformance
I thought about cbest as well but did not see any specs for it on the sheet to be changed when i glanced at it.
When i have time i will run it by a dealer to check.
Old 01-04-09, 09:06 PM
  #49
skperformance
Ok here is a thought , if we know the light out put is realitive to the light source to the sensor . How can we increase it.
We can add a small light which will look stupid or pop the red cover off which should allow enough lumens in to cause the dash to light up more than before. If we could find a clear cover it would be even better.
thoughts on how to pop it off as i do not have the GS repair manual ?
Old 01-04-09, 09:34 PM
  #50
trunkflapp
trunkflapp's Avatar
I didn't dig through all 4 pages of this, but I also agree that the dash lights are way too dim at night. I usually pull up to a gas station, under the lights, and sit there for about 2 minutes. They will get alot brighter. When you pull off, they will dim down just a little, but not as bad as it was before. Hope this helps.....
Quincy
Old 01-04-09, 09:40 PM
  #51
GS4VIPbOSS
GS4VIPbOSS's Avatar
yeah dug through- mines are dim as well -a fix would be ideal - a more tranparent sensor sound interesting.
Old 10-02-09, 11:53 PM
  #52
skperformance
Well i went to the dealer today and had a friend run through the settings. It has a instrumentation level setting .
I changed it from normal to light 1.
It has dark 2 , dark 1 , norm , light1 , light 2 for options.
It seemed pretty bright during the day ( i drive with my headlights on) and most of the night .
Will give it a few days to make sure.
Old 10-04-09, 10:02 PM
  #53
a#'z
a#'z's Avatar
the reason why it dims because your dashboard has 2 sensors on each side, you can see it, its kind of round.. if you cover one of the sides up it dims, or either your dim switch.
Old 10-04-09, 11:27 PM
  #54
skperformance
You obviously have not read this thread by that comment to come to that conclusion which is already noted on how it works.
Old 10-05-09, 05:47 PM
  #55
MrG4Life
MrG4Life's Avatar
Thanks!! Update us with your findings. If this works then I'll be making a trip to the dealer.
Old 10-05-09, 06:59 PM
  #56
GSRSRT
GSRSRT's Avatar
Is there any way to make the cluster more brighter by changing the lights
Old 10-06-09, 01:51 AM
  #57
skperformance
It seems alot better but the night before it was a bit dim for one drive but when i turned the lights on it was pitch black outside where i parked.
Old 10-29-09, 01:07 AM
  #58
skperformance
Ok 2 weeks later and it is a huge improvement.
It is not as bright as it could be but i will take it back and get is set to light 2 . As long as it is not pitch black when i turn the lights on it will be like a normal car. If you park in a bran with no lights it will be black .
So the dealer can adjust it so get it done.
BTW I finally got that stupid slide open sunroof switched so now when i open it with my alarm it tilts instead.
AHHH, the normal life.
Old 10-29-09, 09:26 AM
  #59
sakataj
sakataj's Avatar
any pics of the new brightness?
Old 10-29-09, 03:34 PM
  #60
5t341th
5t341th's Avatar
i'd like to see pics as well
Quick Reply: Anyone else notice the cluster (dash) back lighting seems dim?
