wheel spacer size?
wheel spacer size?
just trying to figure out what size spacer i need to run to have the wheels pretty much sit flush with the fenders..i have 19x8.5 et42 with a 245/35/19 front and a 19x9.5 et 42 with 285/30/19 rear.
i was thinking a 8mm front and a 12mm rear
any and all help appreciated
i will not be pulling the rear fenders...
camber wise i would like to not have a lot of neg camber.. maybe 1.5 degrees max..
front tires have a slight stretch rear tires are not stretched
Well i have n oproblem doing fender mods, i have access to a fender roller so i can roll the fronts if needed, and rears i have a die grinder and can shave..
with your 8mm and 12mm options youd be looking at an effective offset of +34 up front and +30 in the rear. Still wayyyy to conservative.
running a 15 or 20 up front and a 25 in the rear would give you effective offsets of +27 or +22 front and +17 rear. Those are more what you're looking for in terms of flushness.
yeah dude with those offsets youre going to need a 15-20mm in the front and at least a 25mm in the rear in order to even come close.
depends how low you're dropped....much lower than a couple inches and yes itll require fender mods. You'll probably need to at least shave or roll the rear fender (shaving is the better method), wouldn't worry too much about the front fender.
