15mm spacer??
12-04-08, 08:00 PM
15mm spacer??
on my gs430 running 15mm spacer would I need extended studs?
12-04-08, 08:16 PM
dubsonlexus
Quote:
Originally Posted by
racinjasin
yes ! running any spacer the extended studs are reccomended
12-04-08, 08:18 PM
yes you would need longer studs. you can also buy kics spacers with the intergrated studs. installation is easy. no hassle of pounding out the old.
12-04-08, 08:19 PM
we have a new vendor that is selling the bolt on Type II vs, I had them on a previous lexus and they are great and priced good. It takes about 5 minutes to install and you dont replace any studs and they remove easily also. check it out!
12-04-08, 08:37 PM
yeah, that vendor is selling the Ichiba units, which are supposedly the best out there aside from maybe H&R. you'll either need extended studs or the spacers with built in studs.
12-04-08, 08:46 PM
ok so for anything greater than 10mm i'm gonna need extended studs right?
Therefore im guessing we need longer lug nuts too?
12-04-08, 09:12 PM
dubsonlexus
burma
no even the 5mm spacers the studs are recommended
12-04-08, 09:58 PM
yep...5mm its recommended to run longer studs. Its easy to pound them out and install the new ones.
12-05-08, 01:22 AM
Master Thread Closer!!
Well, I ran 5 mm spacers and did NOT install the longer studs....worked fine....still had plenty threads for the lug nuts.
12-05-08, 08:20 AM
shame on you Pete...for shame.
12-05-08, 10:35 AM
speedaddic
LOL....do i give myself an infraction? Ban myself for a week?
12-05-08, 02:32 PM
if you have wheels with the big center caps that cover the lugs, be careful that the extended lugs will clear the center cap.
i personally ran into this problem..
good luck!
4play4dr
Suspension and Brakes
21
07-07-15 03:20 PM
Vip.Status
05-17-11 04:54 AM
joeker
10-06-10 02:15 AM
jnguyen87
10-15-09 02:01 PM
wongerZ
01-28-09 06:30 PM
15mm ,
clublexus ,
extended ,
gs430 ,
lexus ,
longer ,
lug ,
lugs ,
nuts ,
spacer ,
studs
