It's not just the lamp failure problem, it's my 3rd brake light is always on and it lights up when I press the brake like the inner and outer brake lights.. :'(
I figure I might have soldered it wrong
You probably bought wrong ohm size resistors (load equalizers).
Again, my suggestion...disconnect what you did....and remove #4 pin from lamp out module.
This is one of the reason that I'm afraid to get lights for my car.. Don't want to dealt the the headache with aftermarket s******..I'd stick to the OEM..Plug and Play..baby!!
for the individuals with just the indicator on thats an easy fix, the ones with issues like what is stated above becomes frustrating, some even had taillight housings burn up due to cheap resistors and so on.
That's why I went with the Sonar's, those and the JP's seem to be much more reliable and hassle free than some of the tails on Ebay (although I have to add that I had problems with 1 of mine 5 months after install, will probably have to replace). They were plug and play and mine had resistors for the inners and outers so no dash light either.
I'd try to undo the resistors you soldered in and deal with the dash light in another way. From what I understand, it can be easily resolved by taking out the bulb if you're more comfortable with that than messing with the wiring harness.
JP'S are plug & play Don't have to worrie about any dash light's
its amazing how a little indicator light will cause so much heartache!
its also amazing the excuses people have for not modding....
