C.E.L is on and goes off.......
Old 12-08-08, 10:07 AM
dusouth
dusouth's Avatar
Default C.E.L is on and goes off.......
I got a 2000 gs300,for the last month I've been getting a check engine light that will come on for a few days and it will go back off for a few days. I don't drive the car as much as I used too, but I am wondering what it could be since the car still runs well.
I tried to take it to the dealer but they told me to bring it in when the light is on. Of course it never comes on when I decide to take it in.
Anyone know something I can check for that might make it throw a cel?
Old 12-08-08, 10:30 AM
FrankT
FrankT's Avatar
It could be many things...
I call BS on the dealer, the code is stored.
Unless you get the codes read using a OBDII reader all we could do is guess and nothing more.
Old 12-08-08, 12:49 PM
JoelGs
JoelGs's Avatar
The only ways that you can ask the service writers is ...to speak to the master tech..they'll give you some advices on the opt code..Usually, the writers doesn't know a things....Any codes that pops on and off will be stored in the PGM...
Old 12-08-08, 01:00 PM
djspawn00
djspawn00's Avatar
The dealer will probably charge you an arm and a leg to see what the code is... you can always just go to an autozone and have it scanned for free...
Old 12-08-08, 03:33 PM
GS FONZy
GS FONZy's Avatar
Post O2's. Next time it comes on, go to autozone or what ever parts store that offers free obd2 readings.
Old 12-08-08, 03:54 PM
swat1727
swat1727's Avatar
it was o2 for me last time it happened.
Old 12-08-08, 07:05 PM
dusouth
dusouth's Avatar
i'll try autozone wednesday when im off work. i didn't know autozone could scan for free.
btw today it came back on when i started the car and went off when i punched the gas to merge into traffic on the freeway.
Old 12-08-08, 07:21 PM
GS FONZy
GS FONZy's Avatar
Just hope it is your O2 going bad and not the cat.
Old 12-08-08, 08:11 PM
dusouth
dusouth's Avatar
its funny you said that because my heat shield was rattling about 4 or 5 months ago and i took it to a muffler shop and they thought that the rattle was coming from the cat, so they cut it out and looked at it , and welded it back on and said nothing was wrong with it. so they put a couple of tack welds by the heat shield and the rattle went away.
now please tell me that it was alright for them to do that?
if not... when i have it checked out , if they say its the cat, i will be pissed
Old 12-10-08, 11:12 AM
dusouth
dusouth's Avatar
Ok I just went to autozOne and the code was...p0171 system too lean bank 1. What is that suppose to mean
Old 12-10-08, 11:37 AM
GS FONZy
GS FONZy's Avatar
It means your engine is intaking more air then fuel, the mix is lean. I would start by cleaning your maf and checking for any vacuum leaks on the intake and manifold.
Old 12-10-08, 11:44 AM
dusouth
dusouth's Avatar
thanks. don't what i would do without my CL brothren
Old 12-10-08, 12:17 PM
FrankT
FrankT's Avatar
You may also have an exhaust leak at bank1 , cylinders 1,2,3...
Old 12-10-08, 12:24 PM
Debonair
iModerate
Debonair's Avatar
I also hope they cleared the code completely so you can see if it comes back again.
Old 12-10-08, 01:55 PM
dusouth
dusouth's Avatar
The fonz is the man! From the 70's to the present. Cleaned the maf reset the ecu and bam! The cel is gone.
Quick Reply: C.E.L is on and goes off.......
