245/50/16 on stock rims?
I tried search, but could not find answers. I need new tires on my 2001 gs430. I was hoping to go a bit wider but stat with stock 16" rims. Has anyone run 245/50/16s on the stock rims? Any suggestions on how wide I can go?
Yes, it will fit. The overall diameter of 245/50/16 is about the same as the diameter of the stock size, 225/55/16. I don't believe you'll have any rubbing issues. There is a CL member who has this exact size -- IAGS400. If you do a search on his name, you should be able to find some posts about it. Hope this helps.
e
e
245/50-16 fit on the 16 rim and are a great tire size. On the back. The fronts rub on a suspension member on the inside wall of the tire and you chew up the inner sidewall. Any guesses how I know?
e
Wanted a bit more bite on my car and went with the 245 50/16 and ate up the inside of Pirelli P Zeros. Thought maybe it was the tires and switched over to Goodyear F1s and that's when I realized the rubbing problem when we got strange results when we looked at force measurements on the car. Otherwise, a great size. Right up until you see the cord on the inner sidewall. Live and learn.
Guys: OK, thanks. I wasn't that worried about the tire/rim combo. I had run something similar on an auto-x racer years ago. The rubbing on front was primary concern, especially given the sidewall bulge.
Ron430: Thanks for feedback. Did you have rubbing on factory or aftermarket rims? I've done a little measuring and it looked like the OEM rims would clear the 245s, but I'm basing my calcs on a cutout from a 16x8 rim.
Also, I've checked the manuf's website, and the tire manuf does state that a 16x7 is in spec for a 245/50/16 tire. I've seen the combo run in the aut0-x circuit, but did want to get a feel for real world usage.
The first notice I had on mine was when Custom Alignment did an on the car balance. It worked and they balanced but the force readings were screwy. It seems to be that the Pirellis lasted longer than the Goodyears but both had the same problem. I had an unusual creaking from the suspension and took the car into Magnussen Lexus and got one of their better guys to go for a ride with me. He definitely heard it. Brought the car in and put it on the rack and immediately saw that the 245/50 was rubbing on the inner sidewall on a steering component as I remember. You might be able to get an aftermarket wheel with a different offset to take care of the problem but the benefit of the tire is not enough for the hassle on my car. If you go ahead with them on the stock rims, good luck.
