This is how I see it (TRD Aristo Gauge Cluster inside)
have this company seeing if they can source me a trd cluster for the gs
http://www.aj-racing.com/shop/produc...cat=475&page=1
this is a altezza cluster
Here is my new setup. The airbag cover is slightly lighter than the wheel because it's actually dark grey. The color difference should be adjusted in stage 3 though.
Also, about the high temp gauge, I checked the service manual and with a scan tool and the fans do (and are supposed to) kick on at 193f / 90c. So, the temp is correct and okay. I even changed the temp sensor to be sure. It only gets that hot while sitting at idle, though.
