No Heat in the winter help!
I have a 1998 Gs300. Yesterday my blower stopped working. I don't know much about electrical and that kind of stuff with the ac/heater. The first thing to do was I checked the fuse in the driverside kick panel that said heater. Nothing different. My controls all work it says its on full blast but nothings coming out. I put the defrost on just to see if some heat would rise out of the vents to help my windshield and my AC light starts flashing. Anybody got any ideas. I got to go to work but anything will help. Thanks
Sounds like the blower fan is shot. If you open the glove box, I forget if it gives you access to the fan wires. You may have to remove the pass. kick panel, just some screws or push pins. Work the a/c or heat like normal, pull the connector and using a test light to the connector check and see if you have juice to any of the wires (but it's usually a red one). If you have juice to the wire that feeds the fan, it's most likely the fan motor.
I think my AC light is flashing bc i took out the fuse(then lost it
. Whenever its stops raining Ill give it a shot. +1 for heated seats, the only thing keeping me warm.
yo i got the same problem !!!!!!!!!!
nothing works at all, the climate works it says its on but
there is nothign blowing out !
only thing about mine is my ac light is not flashing
but other then that we kinda got the same problem !
https://www.clublexus.com/forums/gs-...help-asap.html
posterboi
Performance & Maintenance
01-02-06 11:48 AM
