Car not starting guys ....
Old 12-28-08, 07:33 PM
VipDout
19x11.5 -51
VipDout's Avatar
Actually I have been unplugging the Accelerator petal position sensor
getting to the TPS now and replugged the battery and no love ...
Thanks for looking
VipDout
19x11.5 -51
VipDout's Avatar
Originally Posted by chrispy
Early GS400s have leaky power steering pumps that drip onto the alternator about a drop a day until the alternator dies. It happened on my last GS.
were you able to even start it though ?
Old 12-28-08, 07:39 PM
japspec
japspec's Avatar
Originally Posted by BippuPxr
I have had a minor leak recently But ...
My car has a new battery so it would still start for 5 mins then die ...
thanks thou ., keep them coming guys
Yea i had a new battery but it turn out that the leaking powersteering pump messed up my alternator and basically my alternator wasnt charging the battery and i was reunning off of straight battery until it died. Fix the leak and hit me back when i do my 2jz swap Ill hook you up on an alternator or powersteering pump if you need them. I had to replace both. Just let me know.
Old 12-28-08, 07:40 PM
whazzzzuup
whazzzzuup's Avatar
That sounds like symptoms of a bad alternator. Take off the alternator and get it checked at your local auto store. The car should be able to run without the battery connected. It is needed for starting purposes only. After you get the car to start, unplug the battery and see if the car shuts off. If it does, then it is the alternator.
Old 12-28-08, 07:43 PM
japspec
japspec's Avatar
Yep a drip a day and kiss your alternator r.i.p. happened to me.
Old 12-28-08, 07:46 PM
VipDout
19x11.5 -51
VipDout's Avatar
EVEN jumping the car .. It wont start , I dont see how the alt . is needing to be checked ...
Old 12-28-08, 07:47 PM
VipDout
19x11.5 -51
VipDout's Avatar
what are the advantages of unplugging the throttle position if the battery has been off for 15 mins ..
Thanks , any more thoughts of my alt. please no need to post... I understand how the car works .. thanks
Old 12-28-08, 07:53 PM
istundra
istundra's Avatar
Sorry to hear of your problem.
Did you unplug the harness only?
or
did you disassemble the whole unit from the car?
Might want to check the connections if you have not done so.
Goodluck!
sam430
sam430's Avatar
If it starts with a new battery and runs out later- then it's likely the alternator. You said that you jump the battery - make sure the battery cable is of adequate guage and that the car jumping it has a battery with enough amp. It should have atleast clicked or tried to crank.
Your fuel pump can also go bad- but if it starts then it's unlikely the source. Your key may not turn all the way - unlikely but worth thinking about.
Make sure everything else it connected before you crank it again.
How did the problem come about? Did it just happen one morning? Did the lights flicker while it was okay when you drove it recently?
Old 12-28-08, 07:56 PM
VipDout
19x11.5 -51
VipDout's Avatar
Its very hard to get to ... so prior to taking it off the car by disconnecting and reconnecting from the harness ..
and rating from 0-10 how hard is getting to this ... from the looks of it ...very tight spot .. I might say 6-7 ? only held on by 2 bolts but the whole harness is in the way ...
Old 12-28-08, 07:58 PM
japspec
japspec's Avatar
Just check it and fix that leak asap, trust me.
Old 12-28-08, 08:00 PM
VipDout
19x11.5 -51
VipDout's Avatar
_____________________________________________________________
Sam I have one of the most unique air bag systems on the forums ... I have also 2 40 amp compressors (AZ)that I understand almost killed the old battery .. instead of charging it I replaced it for free
Jumping a car was/is simple .. and I have to keep my foot on the gas to kick up throttle .. because my alt . is not powerful enough for 80 amp draws ..
The car was on and I was airing it up prior to driving. .. walked away .. and the car was dead .. I was thinking that the compressors killed it but I know that wasnt the issue. Its something related to the car not starting at all even with a strong crank ,
I have read the codes ... No alternator issues
Old 12-28-08, 08:08 PM
VipDout
19x11.5 -51
VipDout's Avatar
reference ?
P1120 TP Sensor Out Of Range Low (Ratch Too Low)
P1121 TP Sensor Inconsistent With MAF Sensor
P1122 TP In Range But Lower Than Expected
P1123 TP In Range But Higher Than Expected
P1124 TP Sensor Out Of Self Test Range
P1125 TP Sensor Intermittent
P1126 TP (Narrow Range) Sensor Circuit Malfunction
So out of range ? what does anyone know what the stock range is and how to read what the range is at now ? just an ordinary multimeter ?
Thanks
Old 12-28-08, 08:10 PM
jcat_350
jcat_350's Avatar
if your alternator was gone you wouldn't get a CEL. However, your alternator not providing enough power to properly run your complicated engine's electronics will definitely cause problems.
think about it....TPS, MAF, they're all electronic, thus need a certain current to work properly. Without letting your battery fully charge (that is with a charger that plugs into the wall, not just a booster pack or jumper cables), you won't get anywhere with a bad alternator.
Old 12-28-08, 08:11 PM
sam430
sam430's Avatar
I see... sometimes we miss the obvious - have you checked the fuses/relay? especially for the fuel pump? Strong crank pretty much rules out the alternator. Does it smell burnt? might be your air bag system short circuited something.
Quick Reply: Car not starting guys ....
