Car not starting guys ....
#62
thanks to Rene thank you sir ! I have a bad Crank sensor I believe after checking it tonight ... I put my Tb back in and adjusted the tps and it cranked over but did not start .. I have put my stock TB back in the car and took out the one from Florida ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Now to test a crank sensor ! caoboy wanna drive up and we can obd2 test your car ? its a ten mil bolt and unplug a sensor ...
lemme know and Thanks guys
the obd2 didn't read anything about a crank sensor ... I will look up for a used one to test if no luck ..
Thanks Guys
Thanks Guys
#63
FlavesLex ... just read the comments you had wrote ... you a real homie , thanks again for all your help ...
I dont believe i have anyone to let me test a 100.00 part so I will order one tomorrow and test it out ... if it doesnt work im in hell and I will have a place for you to crash haha
we'll see how the test goes but i know for my BMW if my crank angle sensor went out then I wont be able to start the car .. keep you posted
#66
James, sorry I couldn't get to this earlier, I usually zone out on the weekends...
To test the Crank Position Sensor, just ohm it out, it has 2 pins
![](http://i126.photobucket.com/albums/p115/FLAVIOSO/CrankSensor.gif)
Cold 1630-2740 ohms
Hot 2065-3225 ohms
Obviously you'll be checking for the cold indication. Since you already ordered a new one, check that one so you can see what you should be getting on the one that's installed.
Cold 1630-2740 ohms
Hot 2065-3225 ohms
#72
James to save you time and effort, just bring it to the lexus dealership bro, just pay the diagnosis fee (depending on the dealership its anywhere from 85-130 bucks) Let them find out whats wrong then take it back and you fix it bro..
Just my .02 cents, because i want to see this car up with the new wheels already!!
#74
yikes this thread is giving me nightmares since my car wont start either and I am just about to begin diagnosis. Anyway lots of great ideas on where to start here.
James,
Thanks for leading me to this thread and I see you will be at the Wekfest on the 8th. I will be there also but with the NSX group. Hope your able to make it.
James,
