Yet other question about wheel offsets
I don't know the answer...but here's something I've used.
http://www.1010tires.com/WheelOffsetCalculator.asp
I referenced the stock wheel with 16in 7.5 and 50mm offset. The rear was okay using 30mm spacers. The front sticks out using 25mm spacers (20mm should be good). Not lowered.
hmm, almost the same setup on the wheels i am getting. Got the wheels and not sure if they will even fit. Not to caring on fender rolling. I have 19x9.5 an 10.5 20off From what i have seen they should fit no problem rolling the inner lip on the fenders. but if i flip them so they are neg 20..will have to stretch tire and fender pull i am assuming?
with a negative 20 yes you will have to make some serious fender mods, especially if you are lowered.
what rims/tires do you have on now? If you shave the inner lip of your fender I dont see you having too many problems, maybe a light pull if absolutely necesary.
