Recommendation from Tech support at Apexi, differs from clublexus?
I asked on here about hooking up the Apexi NEO on my GS430, you guys recommended something like t10-e (i think). I wanted to double check with Apexi to make sure I was doing it right and they said to use t11-b, same diagram used for a sc430. Now Im all screwed up in my thinking. Here is what the two diagrams look like.
well i guess it depends, do you have both connectors or only one?
if you have both, i guess try it both ways and see which is the right one? i don't see how it could differ, unless your advice came from a GS400 owner rather than a gs430 owner.
it looks as though those are two different connectors on the harness... by the fact that there are different receptors with different numbers of pins. Maybe i'm seeing it wrong and they are two different zones of the harness?
i'd PM gs fonzy, i'm almost positive he has the neo and has installed it before.
passnu2
11-29-10 06:30 PM
mannoor
Performance
11-10-09 05:12 AM
mannoor
11-08-09 04:58 PM
Chops@MVP
Club Lexus Vendor Marketplace
11-18-08 07:14 PM
