Loud steering noise in park
Old 01-04-09, 12:56 AM
shabbyblue
shabbyblue's Avatar
Default Loud steering noise in park
When my car is parked I keep turning my steering wheel back and forth and is making a loud screeching noise. I checked to see if there was power steering fluid leaking, but can't find any leaking out are on the ground. Do you guys now what this can be? I can't really hear the noise when I'm driving I'm confused.
Old 01-04-09, 11:12 AM
GS FONZy
GS FONZy's Avatar
Change your belt!
Old 01-04-09, 05:25 PM
UncleRay
UncleRay's Avatar
^-- What he said.
Serpentine belt.
Old 01-04-09, 05:40 PM
BLAZE
BLAZE's Avatar
Sound's like a possible power steering pump. Did you check the p/s fluid level? Also describe in more detail the sound you are hearing.
Old 01-04-09, 05:55 PM
shabbyblue
shabbyblue's Avatar
I checked the fluid and it was full? I thought about the power steering pump. but then there was fluid. The sound is like a raking sound are screeching sound? I never thought about the belt. I will check that.
Old 01-04-09, 06:03 PM
BLAZE
BLAZE's Avatar
Do you hear this sound when your wheel is fully turned to one side? Or do you hear it throughout the whole turning process? It is a little hard to pinpoint without hearing it, thus the many questions.
Old 01-04-09, 10:03 PM
habeeb89
habeeb89's Avatar
I had the same problem, but not when I turned the wheel, it was all the time. It turned out to be my serpentine belt.
Old 01-05-09, 11:59 AM
shabbyblue
shabbyblue's Avatar
I hear throughout the whole turning process. One side seems to be louder than the other.
Old 01-06-09, 08:02 AM
Steelz41
Steelz41's Avatar
I've been experiencing the same noise on my '98 gs400. My boy had his bushings go out so he thought that might be what it was. Had the shop check the bushings but that wasn't it. So...... This belt? Where is it and is a DIY?
Old 01-06-09, 02:55 PM
shabbyblue
shabbyblue's Avatar
I just came back from the shop. They said there is nothing wrong with the car. I can't hear anything while I'm in the car. I can only hear when I turn the wheel outside of my car. i did the for the first time last week and that is when i notice it. I just sounds kind of loud. The guy at the shop said when you turn the suspension is going to make some noise. The sound is almost like my 5.0 mustang when i turn the wheel. Anyways can't hear the noise when I'm in the car and it still turns and doesn't leak power steering fluid. Maybe, my car is just getting old I do have a 160,000 miles on it.
JOHNBRAY11
RX - 1st Gen (1999-2003)
28
06-13-22 06:54 AM
kambam3627
05-20-19 08:29 AM
watch37
Hybrid Technology
01-08-13 05:25 PM
12340987
05-15-09 08:45 AM
Quick Reply: Loud steering noise in park
