Frustration abounds: My Garmin GPS & GS400
Hi All,
I own two different Garmin GPS units. Recently, they've both stopped working in my car (GS400, '99). I use a typical cigarette outlet to connect to the GPS. Previously the Garmins worked fine, but something has happened in the past month. Neither Garmin will work in either outlet. However, when I plug my cell phone charger into the same outlets, I can successfully charge my phone. The red lights on the power cables come on, but the Garmins aren't "turning on". I thought it might be a fuse in the cig lighter, but then why would my cell phone charger work?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Thanks in advance.
Thanks in advance.
I've tried the Garmin's in my wife's car (Accord) and they work w/o a problem. I even went and bought a new charge cord thinking it was a connection problem, but that wasn't it. I've also tried the Garmin's in the center console and the same issue exists- they won't turn on, but my cell phone charger works.
Drew- agree that it's weird, that's why I'm so frustrated.
Garmins also work when they're plugged into my laptop. It's got to be something with the outlets, but for both of them to have the same problem is the annoying part.
check your cars battery mine had the same problem and the battery was going bad in the car, once i replaced the battery the Garmin began to work on car cig power again.
In the mean time just give it a full charge and run it cordless
This makes no sense to me either. Are you sure your cell phone is charging or does it just appear to? Could your Garmin may be drawing more power than the cell phone and therefore causing a load problem with the outlets? I would think they would draw about the same amps.
Right now, in my 99 GS, nothing will work with my cig. lighter but my console lighter works fine. I'm still trying to determine what the problem might be and I've narrowed it down to my cig. lighter socket.
The local Lexus dealership isn't much help with these types of problems. I just need their advice, not their time even though I know this takes a minor amount.
I have experienced the same problem with my center console outlet, and i do believe I know what it is.
Whenever I plug my cell phone charger into it, it works perfectly. But whenever I plug my dc/ac converter into it, it doesnt work. Actually it does power up (it has a little green light on it which actually lights up but is extremely dim. And its actually flashing from very dim to off.)
Now my converter did actually use to work with this same outlet, but since then i have installed a few items, (direct ipod unit, a/v unit, lux-link alarm, tein edfc, and sense-o-shock). I do believe i tapped into the center outlet console outlet for possibly at lease one of these items, therefore i believe the problem lies with the amount of current being drawn from that source. (the center console outlet). Maybe a fuse problem or somehow it just cant handle that much power being drawn from it. Which is why i believe the cell phone charger works, due to it drawing less power/voltage, versus the dc/ac converter which im sure need a lot more power to work.
One of these days i will open up my console and verify this. But i am pretty sure that is the problem.
Also i have no ciggarette lighter because i installed an xm unit permenantly in place of the ashtray, cigarette lighter.
Thanks for all the advice/ideas, I appreciate it everyone.
kevin3344
10-24-18 03:58 PM
oldglo
08-16-15 10:21 PM
