HELP! my gas pedal goes stiff above 2300 rpm? also does anyone know what this part is
it's basically the wheel (throttle cable cam?) and what holds it in place that the throttle cable connects to and is connected to the throttle body. i went to lexus for the part # but lost it
. wondering what part this is and if anyone would have it/knows where i can get one at discount ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
EDIT: i have found out there is nothing wrong with the throttle cable. the problem is the throttle cable cam does not turn smoothly, which is probably due to improper installation. so now my question is, does anyone know how to install the the throttle cable cam?!![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
heres a pic of it (taken off of redjeeper's spark plug DIY post)
![](http://i43.tinypic.com/29lh72w.jpg)
what had happened was, while changing the spark plugs, my brilliant friend took off my entire throttle cable cam instead of simply unhooking the cable. we tried putting everything back together but now every time I go above about 2300 rpm, the gas pedal gets stiff. when i press down on the stiff pedal the rpm just jumps. i've tried loosening the throttle cable and tightening it as well. still does not fix this problem. anyone know a solution? ANY input on this situation would be much appreciated
Looks like all you need to do is readjust the throttle cable.
Look to the left side of the pic, the threaded section needs to be secured to the bracket (cable stop) with the two nuts. The cable , IIRC, should have about 3mm of slack.
And don't let your friend touch your car anymore.
OH wait, that is not your pic, check you cable anyway...
If you want this headache to be over, bite the built and buy a new accelerator pedal position sensor.
These things are not meant to be disassembled.
Good luck
Good luck
