Nav Problems can someone help or steer me in right direction
#48
LEXUS:
Generation 2/3
2001-2005 GS300
2001-2005 GS400
2001-2003 LS430
2002-2003 ES300/330
2001-2004 RX300/330
2001-2003 LX470
2002-2005 IS300
2002-2004 SC430
2003-2004 GX470
Generation 4
2006 GS300
2006 GS430
2004-2006 LS430
2004-2006 ES300/330
2005-2006 RX330
2006 RX400h
2004-2007 LX470
2005-2006 SC430
2005-2006 GX470
Generation 5 Navigation
2007-2009 GS350
2007-2009 GS430/460
2007-2009 GS450h
2007-2009 ES350
2007-2009 RX350
2007-2009 RX400h
2007-2009 GX470
2006-2009 IS250
2006-2009 IS350
#49
http://www.sewellpartsonline.com/par...l.asp?id=88792
be cheaper and better off to pull the nav unit, but a non nav climate control assy and replace the headunit with a aftermarket nav unit
#50
Any updates from someone who has upgraded from a gen2/3/4 to a gen5? In searching the forums, I am finding conflicting results, as to it being a relatively easy swap like sakataj did here, to it being a nightmare bc of the difference in hardware... (screen size?)
I have a 2002 GS with ML Nav, want to upgrade, and just want to know if the gen5 is even an option...
If all else fails, someone needs to fabricate a way to mount the new Apple iPad into the dash, and create an app that controls the climate, navigation, show car and trip info, play music and movies, change and rotate the tires, etc. Ha!
#51
hmmm...not sure where you came bout someone saying it has a difference hardware. only thing different would be the nav ecu and as long as its PNP it should be fine....screen is the same size.
i would love to 100% know if the gen 5 is a update. i swear have heard it is and i thought i looked into one but for the price i passed.
lol @ the apple iPad....dunno what i think of that thing yet. ALOT of them gonna get broken quickly i can tell you that
#53
2007-2009 GS350
2007-2009 GS430/460
2007-2009 GS450h
2007-2009 ES350
2007-2009 RX350
2007-2009 RX400h
2007-2009 GX470
2006-2009 IS250
2006-2009 IS350
to let me unplug it and plug it into mine to "test it out". i mean if it plugs up and works thats over half the ?'s answered
i think u mean the same thing but its not the "fitment" that's the issue. its whether is truthfully plug and play
#54
sakataj,
Would the gen5 nav out of a Prius for example (like the gen4 you have in yours) also do the trick? It can be ANY Toyota gen5 nav right, not just the Lexus ones you have above?
If that's the case, at least that widens the search a little on the gen5 nav search...
#56
sakataj,
Ouch... Ebay has a gen 5 for 1400, with no return possible...
I guess tho if it were to work like the gen 4 swap, its at least in range of what most of todays aftermarket Navs run...
http://cgi.ebay.com/ebaymotors/LEXUS...item3a515d7ab8
and actually that is the gen 5 nav ecu but it says its for europe only (i wonder if a us disc would work though)
if u read it, he says its a generic pic and actual item doesnt look like that but if the gen 5 plugs are like that, it might work. the plugs visually appear simiar but who knows since he says that isnt the pic
this IS a USD gen 5 nav (it comes with the TOUCH SCREEN DISPLAY, RADIO/CD CHANGER, CLOCK ASSEMBLY, NAVIGATION ECU WITH MAP DVD AND GPS ANTENNA but all you need is the nav ecu)
http://cgi.ebay.com/ebaymotors/LEXUS...item3ef149e607
again here is a correct one and this one is JUST the nav ecu
http://cgi.ebay.com/ebaymotors/LEXUS...item3a526272a2
but look at the price with no return....pfffttt
easiest way guys is if you know someone or if you or your wife/mother in law/gf/best friend owns a car with a gen 5 nav be it a toyota or a lexus to see if they will let u unplug it and try it on yours....
#60
i been searching for bout 35 mins abel....i CANNOT find a part # on that nav ecu. would be easier to find if we had a list of the toyota's it came from or if someone knows someone with one of these cars and they would look for them. im curious to know this myself...u FINALLY gonna change your bad nav ecu?
2007-2009 GS350
2007-2009 GS430/460
2007-2009 GS450h
2007-2009 ES350
2007-2009 RX350
2007-2009 RX400h
2007-2009 GX470
2006-2009 IS250
2006-2009 IS350
2007-2009 GS350
2007-2009 GS430/460
2007-2009 GS450h
2007-2009 ES350
2007-2009 RX350
2007-2009 RX400h
2007-2009 GX470
2006-2009 IS250
2006-2009 IS350
