K2 Hid 8000k
#121
That's wierd because i see that u have yellow foglights, are all the GS's fog lamps yellow? because if im not mistaken, I could have sworn i saw a GS with halogen lights, including the lamps, they weren't yellow
ShOwGS
ShOwGS
#122
ShOwGS
ShOwGS
#123
O.K. a1exus, last question (at least from me) are your new bulbs
"D2R or D2S"?
Because looking at the several pics you provided, the light appears to be blasting thru from every angle! Like a flood light. I now understand that the D2S would probably do this since it does not have those "strips" painted on like the D2R used in "projection" applications. So apparently the D2S is going to throw out more light output due to it not having that strip on the bottom....................?
"D2R or D2S"?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#126
"D2R or D2S"?
"D2R or D2S"?
#127
RX 300 & 350Z Guru
D2R - WITHOUT STRIP!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Isn't the D2R used for reflector housings and the D2S used for projector?
-Nick
#128
Originally posted by LexRX
Souldn't that be "with strip"![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
-Nick
-Nick
Yeah, he messed up on the post.
A1 do you blind people at night? I heard the light is more scattered with the D2S
#130
#131
i dont know about blinding.. i didn't pull over and ask .. oh did i blind you?
#132
"D2R or D2S"?
"D2R or D2S"?
No I'm afraid you guys are misreading my post! It is very clear: I now understand that the D2S would probably do this since it does not have those "strips" painted on like the D2R" What's messed up about that? Anyway, after speaking with my aftermarket shop guys here in Dallas, they say that just replacing the factory bulbs with these "8000k" bulbs will work, but WILL NOT BE AS BRIGHT UNTIL YOU UPGRADE THE BALLAST TO! Can someone confirm or deny this? So our factory ballasts won't power up the bulbs sufficiently???
#133
RX 300 & 350Z Guru
TXSTYLE, what enginyr and I were talking about where you messed up was in your second graphic you posted. You said "D2R without strip." D2R has the strip, so it should have been "with strip."
-Nick
-Nick
#134
-Nick
-Nick
#135
RX 300 & 350Z Guru
Got you!
Listen. I spoke with a vendor who says he can get the bulbs for me in D2S or D2R (the style) what is the "size" I need like H-1 for example????
Got you!
'98 GS Light Part Numbers
-Nick
