window problem
The easiest and cheapest way.....
Take off the door panel, find the plug for the window motor and unplug it. Get a power source (your car battery, a booster pack), some wire (speaker wire, jumper cables, whatever) and get power directly to the window motor via the connector plug. Don't touch anything metal with your power source or let each wire touch unless you want to see a spark show. If it won't move, switch pos and neg around, If that don't work, your motor is shot.
It would be best if you had a booster pack and 2 steel rivits, just more professional.good luck
