Wiper arm hitting hood
I have had this problem since i got the car. I've noticed that the wiper arms (the drivers side at least) make contact with the hood. This has led to the paint being worn off on the wiper arm as well as the hood where its making contact. Here are some pics to see what im talking about. Has this happened to anyone else? What could be going wrong here, can it be adjusted?
My wiper hits the driver side A-pillar when they are on high, and it makes a horrible noise. Anyone have this problem? Maybe I should try to tighten the bolt on mine as well....
Quincy
Quincy
Installed new blades last week and mine did this also. I tried tightening it and still hit the hood when i had the wipers under the hood when off. Finally had the wipers exposed from under the hood and tightend the wiper, now works fine. Just don't have the sleath look of the blades tucked under the hood when off.
I caused the problem for myself, in a sense. The bolt got loose on its own and I tightened it without setting the wiper arm to the lowest position, so when it was fully extended it slammed into the A pillar with remarkable intensity. In my own defense, it was a pretty bad rainstorm and I only had pliers on me to tighten the bolt with--and my hood won't open.
Yes. I just had this problem. Loosening the bolt, forcing the wiper arm down while the bolt was loosened, and then tightening the bolt fixed this for me.
Does anybody have any idea why only the driver side would keep getting loose? I don't know how these things happen. Any advice would be appreciated.
