Not starting after disconnected battery?
Jump started another car off my GS today,and the ground came off the battery (wasn't on tight),and since i've connected it back up,all that i get is the starter motor turning but the engine doesn't fire up?
only got the valet key no master key,this shouldn't make a difference should it?
please help need to fix it before i go abroad in 2 days,and i need the car tomorrow!!
iModerate
Sorry to hear about this. Have you checked all the fuses? That sounds like the most likely cause to me. It may also be possible that the anti theft somehow got activated and and is interrupting the ignition or fuel system somehow.
Although I have done it in the past this is why people recommend not "jump starting" other vehicles from electronic intensive vehicles like out Lexus'.
not checked fuses yet as i had to run off to finish working on another car then had the wonderful rain come ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
just went back out and tried starting now,after a few seconds the starter starts to die,not suprised so tomorrow going to join a battery from another car up for a while and see what happens and check the fuses out
ok will try that,and the anti theft,any tips on how to turn it off?
the other car was jumped with the GS turned off,but hasn't seemed to affect the GS? but there was a small spark while connecting the negative but this shouldn't affect it i think,i've jumped started around a thousand times so far
iModerate
1000 Jump Starts?
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
lol,thats just a rough guess i've lost count how many times i've done it something around that figure i guess,use to have 11 cars so had plenty to choose from to jump from
going to take battery out and charge it overnight on trickle,thank god my dad brought a battery charger,saves me buying one
If the battery cable are loose then you might of just ran out of juice. Also, there is sensor next to the place where you open your trunk and fuel cap. You'll see one little bulb - that is the sensor. Place your vallet key next to it for a few seconds before you try starting your car.
make sure your battery cables are tight and charged first.
GL.
GL.
iModerate
GL.
GL.
See BananaGS' Pics below:
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
GL.
GL.
Here are the instruction:
1) REMOVE the key plate from the key case.
2) Bring the key case closer to the ignition switch within 10 seconds as indicated by the arrow (see pic below). The indicator lights goes out. This means the immobiliser system is automatically canceled. You can then put the key case away. You can not cancel the engin immobiliser system if 10 seconds have past after you inserted they key plate. You need to remove the key plate from the ignition switch and try again from step 2.
4) Start the engine within 60 seconds after the security indicator light goes out. You cannot start the engine if 60 seconds have past after the security light indicator went off. Repeat step 2 again if 60 seconds have past.
![](http://i44.tinypic.com/10mn904.jpg)
so, you need the key plate (vallet key) and the key case. Key case goes next to the ignition switch for ten seconds until the immobiliser lights goes out(see picture posted by Debonair). You have 60 seconds.
