Bought Bad Oil *help*
Hi everyone. Alright i think, well i know i got screw buying oil at walmark. Yesterday i bought a jugg of 5 qt Mobil 1. I changed my oil today and as i was pooring it in, the oil was dark black. It was totaly old oil that got returned by someone else. Spoke to the manager and they will do a oil change for me tomrrow first thing 7am. I already putted on 50 mils since.
Now this is where i need help/advice. What should i do? Should i have them flush my car entirly out with clean oil before putting in new one? Can i buy anything to poor in to make sure that its all good, because for all i know transmission oil could be mixed in.
Thanks
Ben
Thanks
Ben
Forum Administrator
I'd have them save some of the oil they remove from your car (a quart of it) and make sure they write on your receipt what happened.
If you're really concerned send the old oil off to Blackstone for analysis and let them know what happened and you want to make sure its old oil and nothing else (watch them remove and save it). http://www.blackstone-labs.com/free_test_kit.html Maybe you can get the car shop to pick up the $23 cost.
It's likely just old oil and you'll be OK.
Thanks for the replys. I actually checked the seal before buying it. Reason was when i picked it up it was a tad lighter than normal. But it was sealed and i was like it must be good. When i poor it into my car i was short a qt. So i end up buying another qt at autozone. Thats when i notice the difference.
I did'nt pay attention too much to the oil at first cuz it was Mobil 1, extend 15,000 mile. So i thought it was something new and let it slid till i stopped by autozone.
lol. If you change your own oil on a regular basis you can tell if the seal has been broken. I am surprised that the dark black oil wasn't a second dead give away. I'm not sure what the point is in calling walmart or mobil to complain.
Similar thing happened to me back in September, but with AutoZone, I changed the oil immediately without running the car on the bad oil, then again a few days later, haven't had any problems with smoke or strange noises so I'm assuming it's all ok.
Here's the whole story...
https://www.clublexus.com/forums/gs-...nightmare.html
My routine is to use "Motor Flush", or better yet a quart of diesel fuel or even transmission fluid. Poor into the engine and run the engine for 10-15 mins at idle. Then drain and change filter/oil as usual. I do this every 3-4 change. You'd be suprised at how much crud comes out.
I use Rotella T oil. I've been a diesel guy for a long time and, well . . . if it's good enough for a diesel it must be more than enough for a gas engine.
I wouldn't use "Motor Flush", but that's just me. If that happened to me, I'd have them drain, fill with regular bulk oil, drain and refill. You want all the old stuff out ASAP, because as DaveGS4 stated, it's probably just oil, but you ran the car 50 miles already.
Better safe than sorry, Best of Luck.
