hey i have a 02 g430 and was going to put on 07 m45 wheels 19/8.5 50offset and i was wondering what spacers would be recommended for them ,i know 25mm is the way to go with stock wheels please help out thanks
The stock rims are 17X8 +50, so the M45 rims would stick out about 6mm more. I would think a 20mm spacer would look pretty good and sit in virtually the same position as a 25mm spacer on the stock GS rims.
Just buy the adapters with studs on them. Now days with the special thin lug nut you can find studs on adapters as low as 15mm. I don't think I've ever seen then on a 10mm though as that might be too thin even for the new thin lugs.
