Drl"s
#31
#32
ok I got my stuff in the mail today and well it works and it doesnt work lol. With both led bulbs installed and both drls plugged in only the left side works. With one oem bulb plugged in and one drl/led plugged in the drl/led works, but the oem one does not. With both drl/leds plugged in they work together only on high beams.
Im going to get in contact with v-led about this and see if they have any idea as to why and if not then ill dig deeper into it. Any idea what is inside the drl modules? And how they allow the leds to work on both drl and high beams?
I am hella confused as to why, but my brother is good with wiring/electrical so im going to get him wiring schematics for my car and for an LS since they work on that car so he can compare whats different.
On another note the back firing 4 led 194's work and look great.
#34
DRLs are your high beams running at 30%-50% power/wattage. Not sure if 98's had DRLs feature but I thought they all did, could be a blown fuse or bad bulbs if they are not working.
#35
If he's got high beams working, i'd guess a blown DRL fuse.
#40
Not exactly sure what the 3rd Gen LED DRL's do but if you look in the lighting section on CL there is someone who was able to get it so you can get LED DRL's and still have the highbeam function, you have to use some kind of plug in.
