Car wont start
I could use some help on where to look first. I just went out to my car for a run to the store but when I went to start it and turned on for about 2 seconds and then turned off. I tried to start it again but it just churns over but never starts.
A little history: Car has approx. 150,000 miles, I replaced the plugs about 6 months ago and its way overdue for a tune up. I noticed a couple times over the last year that after coming off the highway and stopping the rpms would go down a little and the car woudl stutter just for a couple seconds and then back to normal. I dont know if there is any correlation between that and whatever is wrong now but I am trying to disclose everything I know. The battery is pretty new and all the lights and radio seem to be working fine so I dont think its related to the battery.
Can anyone point me in the right direction on where to look/check first?
Thanks
Thanks
I was thinking about getting a OBD2 error code reader (cant remember what they are called) and checking for error codes.
19x11.5 -51
Good luck with yours ...... I had luck with it starting again and then dieing asap ........ still not sure and its all packed up for the car to go to the shop ..
Heres a quick list of everything that was done for my car in the month is was down 12/28/2008
Spark plugs changed with Irridium
New 850 ccas Interstate battery
Tested Alternator passed 3 times
Checked TPS (in range)
Checked Crank position sensor (in range)
Exchanged Throttle body and found it had a (bad motor) ?
Checked the ECM trouble shooting and works fine
Checked all wires to the Ignition switch and ECM and EFI relay and readings good
Ignition fuse good
All Fuses good
Checked almost Complete Harness No breaks
Checked one coilpack test (low spark)
changed out to a new Serpentine belt
Many more things but those are relevant to this issue and still no luck , Best of luck man . when I find out whats going on I will have it posted up for 99 Gs400 owners
Btw I am about 150k too
Ignition fuse good
All Fuses good
mungrin
Performance & Maintenance
01-01-14 01:14 PM
