Ichiba Spacer 15mm version II? Will it fit clear the studs?
Old 01-26-09, 10:47 AM
Rich27
Rich27's Avatar
Default Ichiba Spacer 15mm version II? Will it fit clear the studs?
Hey everyone,
Sorry for a silly question, but does anyone know if the 15mm Ichiba Spacer II will clear the stock studs?
I'm thinking about getting this spacer so I don't have to worry about replacing the stock studs.
Will the stock studs stick out wit this spacer?
Thanks for the help everyone!
Old 01-26-09, 11:08 AM
sam430
sam430's Avatar
yes it will. You need wheels that have indentation at the stock stud location. Just call them and ask (info I got from the vendor section).
Old 01-26-09, 11:20 AM
Rich27
Rich27's Avatar
My wheels don't have the stock indentation.
Old 01-26-09, 11:36 AM
chrispy
chrispy's Avatar
If you're spacing out the Scaras, the stock studs will not clear because the wheels are multidrilled.
Old 01-26-09, 11:38 AM
Rich27
Rich27's Avatar
Thanks Chrispy. Sounds like I need to replace the studs if I go with 10mm or 15mm. I appreciate your help!
Old 01-26-09, 11:47 AM
chrispy
chrispy's Avatar
You can cut the stock studs so they clear and use a bolt on spacer, but in the end you're going to have to replace studs either way.
Silver'04
12-31-10 05:53 PM
Dragnet
11-01-09 02:30 AM
Wierdazndu
10-15-09 11:20 AM
Maxx250awd
10-01-09 10:17 PM
Rich27
04-03-09 08:39 AM
Quick Reply: Ichiba Spacer 15mm version II? Will it fit clear the studs?
