replacing park/neutral switch, cats in the way????
Well i'm about to change my park/neutral switch, and finally got under the car and it is RIGHT NEXT to one of the cats. It was too hot at the moment to poke around, but it looks like there wont be enough clearance to work on this. Anyone have any advice/suggestions?
FYI, the CEL is showing the p1780 code, and the car currently will NOT shift out of park unless that little button on the shifter is pushed in. And with the CEL on, my car wont pass emissions, which means my plates are expired which means I can't drive my damn Lexus
Heres the car. I plan on dropping it with the NF210 springs, and either painting the roof black, or the lower portion gray or tan. Just gotta get these maintenance issues taken care of first
iModerate
Top black looks nice but is pretty common now - lower body panels grey/tan....not so much. I think it will make the car look older then it is but I could be wrong.
iModerate
Well I got the old one off, and it was a HUGE pain. Now my problem is getting the wire harness off. There is little to no slack, and of course it's towards the top of the tranny. I'm thinking about unbolting the tranny crossmember to gain a few precious inches up there. That should be all I need.
Anyone know if i unbolt the crossmember if the tranny will drop a bit? Of course i'll have a jack under it so it doesn't fall.....
Ok, the job is done. I would say total time was 3 1/2 hours. This is NOT a job for the faint of heart. Access is extremely limited, and you have to get pretty creative during removal/installation. Dropping the tranny crossmember probably gave me an extra inch of clearance which made the job barely doable. I would LOVE to hear what a dealership would charge to replace this part.
Part replacement did solve my problem, now my car passed emissions, the tags are current, and I can move on to the next maintenance job. Replacing sparkplugs and front rotors is on the list. Ive seen the DIY topics on both, and after this job, i'm ready for anything on this damn car
Which part failed? That black box around the shifter that senses what gear you're in?
Mine is freely acessible, then again I don't have a certain thing in the way
Side note for everyone else, if you drop the transmission brace keep a jack under it and don't allow the engine to move too far back. If you're not careful the engine will lean against the firewall and may cause dents or scratches. Then again, it's hard to see around that area so it's not really that big of a deal. But just giving you guys a FYI.
