Car dies/Starts/low/rough idle/no acceleration?!?!
I have searched low/rough idle but every other post says Engine mounts but that cant be in my case.
Long story short it goes like this. Im in the car for about 20-30 min Nav-on Head lights-on Music-on, next music goes silent everything else is fine i thought my cd player skipped but then the navi start going hai wire and going diffrent colors and scrambling, then everything dies so then i figure the battery died car wasnt turned on. So i try to start get a weazzing noise and a wanabe start sound but nothing. I go away for about 20 min come back with jumper cables, try to start again and it starts without the use of the jumper cables, but then the RPM's start jumping from about 400-100 and up and down etc... My car Idles around 700 Rpms on a daily basis. I let it sit for about 1/2hr and car feels like its not getting enough air. I drive and try to accelerate but i get nothing the rpms rise but the car is just trying to accelerate and then at 4k Rpms it kicks in like a MAD horse the rear goes out and VSC starts going crazy i got scared, i let off and try again same thing all day.
I reset the ECU 2 times today and Nothing.
If anyone could plz guide me to a link or throw some knowladge my way I would greatly greatly appreciate it! ( i have read alot of recent threads on loss of power at certain RPM speeds but i dint feel like some of the solutions could help me in this case. Sincemy MAF is not even 1 year old.
Take a look at the battery.
Check for loose terminal clamps or corrosion...
With a volt meter at the battery terminals, check 12+ volts with the motor off and 14 volts with the motor running.
Let us know what you have...
If you said you hit the throttle and gives you a slow response and then immediately rises to 4k instantly, sounds like a bad throttle motor. Check all the the throttle body components like the sensors thats hooked up around the throttle body. Is there a CEL on?
But do check your charging system before jumping into conclusions.
Thanks for taking the time to respond guys! there is no CEL and tomorow im going to my friends shop checking the alternator, and throttle body components maybe i will get some luck.
If you guys have any more input its more then welcome and tx again! I will try to post up new results/solution.
Well for tomorow im
-Cleaning the MAF
-Checking Volts/alternator
-Cleaning the Throttle body
-Buying new Spark plugs
-Then going to friends shop, maybe the shop will have some solution.
if I get no luck im swaping back my stock intake and see what will happen, because it just feels like its choking at idle.
Had no time today do anything hoping i will have more luck on monday.
I have just been having similar issues
Solved buy removing and cleaning throttle body & reseting throttle position sensor
I had to move TPS next to power steering resvior buy 1mm...to far and you get 4000 rpm idle
Here is the how to adjust http://bahamutcars.free.fr/workshop/...nts/index.html
Direct link will not work = ELECTRONIC FUEL INJECTION / THROTTLE BODY / REPLACEMENT
Page FI 36
Page FI 36
Page FI 36
Page FI 36
Quick update.
-low/rough idle fixed for now= Cleaning maf/Throttle body about 30 min job.
-acceleration about 45% better but from 1.5krpm-2krpm car accelrates then bogs at 2.5k rpm then it accelerates again till about 3k rpm then a quick bog then after that the acceleration is smooth but when car was 100% working it was a beast at around 3krpm all the way to 6k.Now it just seems like a gs300 which is bleehhh in speed.
-im getting ready to change the sparks and see what will change.
Now i just have a couple of quick questions.
When the shifter is in park the car idles around 7.5-800 rpm, switch it to nuetral it goes to 1k rpm, then to D it goes to 500rpm and same for reverse. Now is that an ok Range??
while i did a quick drive i started to hear a poping noise right under me. When i would accelerate slightly then let of quickly i would hear a very clear/crisp kind of POP or Clunk could that be the TC locking and unlocking, it happens around 1.5-2k rpm, its pretty loud. Anyone have a clue what that might be?
If its the TC then i have an excuse to get the PI TC 2.8k
any info would be greatly appreciated,still have a bunch of things to check out and see if the slow acceleration will go away.
CRC Map sensor cleaner http://www.crcindustries.com/auto/co...x?S=Y&PN=05110
Give it a try
Link to the work shop manual should be in the first sticky hint hint
Give it a try
Give it a try
Yep thats the spray that i used. And the Work Shop Manual SHOULD BE made a sticky, alot of great info i could of used in the past But its 430/300 only *(
Just gonna throw this out there......but how about bad Catalytic converters??? My friend had bad cats on his S/C Tacoma and it did some similar things that you described. And when I say bad....I mean broken/clogged. Hit them with your hand when they are cool and see if you can hear some things moving and shaking in there.
