Will these wheels fit a 2nd gen GS? i dont want to do any fender mod...
you will be fine in the rear. the front may rub some. depends on what brand tire you go with. some are fatter than others. i suggest running a mild stretch in the front. the front wheel will probably stick out just a tad from the fender.
check out an old thread of mine. i'm 18x9 -30 and 9.5 -28
i dont rub at all and i'm flush.
https://www.clublexus.com/forums/gs-...ork-equip.html
Ok im confused i have 20 9 25+OFFSET on 245/30/20 and 20 10 25 275/30/20 on tein coils and i dont rub ever i need some spacers actually, so if he wants 18s or 19s with fatter tires wont it come out to about the same ?
Steff more knowledge please, lol
The One
Is your alignment off a bit? Also, do you realize you are running two different diameter wheels with those tire specs? The front is about OEM spec (which probably helps with the rubbing, or lack thereof) while the rear is about 1" taller.
I think he would rub too. I have a 20x10 rear and 30offset and stock that thing wasnt even close to clearing. Even after shaving the fenders and getting them pulled I get some rub in the rear. And you runing a fat setup. Eather way I think the margin is close enough that If you bought them and they did rub you would be pissed especially with a bunch of people telling you it wouldnt rub. In my opinion keep looking.
Mike813
Wheels, Tires & Brakes Forum
09-30-11 08:52 AM
