new member need some help
check the fuel filter. If you've cleaned injectors, replaced plugs, had an oil change recently, my money is on the fuel filter. If you're getting a CEL get the codes pulled at autozone and post them here. this should tell us better where to look. That mechanic of yours seems like a real piece of trash. Take the car elsewhere.
So you can see where i'm getting this from, your hierarchy of missing/shaking/pinging problems:
-air filter
-spark plugs
-fuel filter
-clean maf
-clean throttle body
-fuel injectors
-fuel pump
-vacuum leak
-head gasket
-air filter
-spark plugs
-fuel filter
-clean maf
-fuel injectors
-fuel pump
-vacuum leak
-head gasket
billydpowe
06-06-16 01:41 PM
mrmalik750
Performance & Maintenance
20
08-25-07 08:09 AM
