How much did you pay for timing belt and water pump change?
um my mechanic doesnt cut NE corners....sounds like you got some lazy shops around you. i save so much $$$ by not going to my dealer since i found a mechanic i like/trust/friends with (been with him since 1998) no complaints/no problems. but for the most part if you dont have a good mechanic your right it would be better off at the dealer
I paid 350 for labor... waterpump, belt, tensioners, cam seals, ect.
I brought my care into a local Toyota dealer this morning for timing belt, water pump, and seals. They gave me a quote of $675. However, they just called to say that my tensioner is "not smooth" and should be replaced. I told them to put it back together (I'll have my guy replace it) - Lexus wants $215 for the tensioner part. That's why I'm online looking for a better price.
Try to source one from Carson Toyota. You can get the timing belt tensioner for around $60-70 I believe. If it's your accessory belt tensioner that went out, then that will run you about $150 from them.
I'm sorry, but i respectfully disagree. I work at the dealer, I did my timing belt, water pump, tranny drain/fill, coolant drain/fill (pink SLL) for the cost of my price on parts, it was like 160 for all OEM if I do recall. The timing belt kit comes with belt, a couple seals for the water pump, and thats about it. I did this on the 3uz, which is not any different than the 1uz, but I have yet to see 1 cam seal leaking. I have done the belts before, I have yet to do a single cam seal on a UZ, however I have done a few on the the 2jz. Cam seals for the UZs are not easily gotten a hold of either, I fear for the person who must replace it.
Lets compare apples to apples here, half the posts above do not mention what model GS.
Cam seals on a UZ motor is way more involved than a 2jz.
Thank goodness they last quit some time.
Replacing cam seals will almost double the labor rate on a timing belt job for a GS4xx.
If you mechanic says he replaced the cam seals on your UZ motor ask to see the old ones.
If it was my car, I would say yes, but just the belt and leave the idlers, tensioner and water pump for the next 90k.
