How much did you pay for timing belt and water pump change?
#31
So I went to your profile to see that you are inquiring on a GS300...
You do not need any seals to replace your timing belt, if that is what you are asking.
There are 2 cam oil seals and 1 crank oil seal behind the timing belt that you may or may not want to replace.
The water pump has two o-rings for the bypass pipe and an o-ring for the bypass outlet.
#33
16110-49155 Water Pump
16124-46070 WP Gasket
96761-24040 WP O-ring
16325-46010 WP Rear Pipe Gasket
90311-46001 Front Main Seal
90311-40020 Camshaft Oil Seals x2
99366-D1930 Acessory Belt
90916-03093 Thermostat
16325-62010 Thermostat O-ring
13505-46041 Timing Belt Idler
13568-49036 Timing Belt
13540-46030 Timing Belt Tensioner
11213-46030 Valve Cover Gasket INTAKE SIDE
11214-46011 Valve Cover Gasket EXHAUST SIDE
spark plugs
and 12qt transmission flush
i got all this parts and labor for $750-$800 i forgot.
spark plugs
#36
spark plugs
spark plugs
Ok I just pulled up those numbers and some of the parts come from GS 92-94 ? wth? Can anyone confirmed these numbers? Those parts are from Carson Toyota.
Part Number: 1356849036
Engine - Camshaft & timing - Camshaft & timing - Timing belt Timing belt, sc300, gs300 - 3.0l 1992 - 1994 $28.68
Part Number: 1354046030
Engine - Camshaft & timing - Camshaft & timing - Tensioner Tensioner, sc300, gs300 - 3.0l 1992 - 1994 $62.22
Part Number: 1350546041
Engine - Camshaft & timing - Camshaft & timing - Idler pulley Idler pulley, sc300, gs300 - 3.0l 1992 - 1994 $73.13
Part Number: 1611049156
Cooling - Water pump - Water pump - W/o coupling W/o coupling - 3.0 liter 1998 - 2005 $128.64
Part number 1611049155 was superceded by part number 1611049156.
Part Number: 9091603093
Cooling system - Cooling system - Cooling system - Thermostat Thermostat, sc300, gs300 1992 - 1994 $15.79
Part Number: 1612446070
Cooling - Water pump - Gasket Gasket - 3.0 liter 1998 - 2005 $7.49
Part Number: 99366D1930
Maintenance & lubrication - Engine service - Belts & pulleys - Serpentine belt Serpentine belt, gs300 1998 - 2005 $23.78
Thanks,
Andy
#40
I just did change my timing kits for about 2 months ago, I only paid for the part which cost me around $350. My friend and I did the labor ourselves. I did take a step by step pics. I took only one pic before we removed all the components. I would say replacing the Cam Seals was kind of hard at first, but then we managed to replace it. Good luck with yours. Oh, mine is 2gs400 '98
Timing belt
Idle
Tensioner
Pulley
Water pump (gaskets)
Thermostat (gasket)
Cam seal (2)
Crank seal 1
Engine belt
Timing belt
Idle
Tensioner
Pulley
Thermostat (gasket)
Cam seal (2)
Crank seal 1
Engine belt
#43
Exclude the gasket kit and part numbers as they are from a 92' LS4. But pricing is similar, don't forget to check your idler and tensioner bearings as it would not be fun to do the T-belt again because of a pulley. And Cam seals on the VVT-i aren't mandatory, but again are insurance, as they raaaaarely leak.
05SC430PB
06-26-13 09:18 AM
trackball
Performance & Maintenance
18
08-12-10 12:10 PM
